So, this is a question that won't really matter for many years, until I have stupid amounts of extra money too risk on a fried cpu/mobo. But, given the ability to keep the CPU extremely cool, what kind of overclocks would an Extreme core Intel CPU be able to get? Like, given the ability to keep up with the heat of crazy voltages/heat could the 6950x get up to 4.7/5.0 ghz?
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/635972-phase-change-cooling/
I'm not too sure on how high the overclock can get, but as you apply more voltage more heat is produced. This effect increases electrical resistance in the CPU, and cooling it down decreases, which is why LN2 is popular for OC competitions. The only issue I can see with this kind of cooling would be condensation and startup time.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/635972-phase-change-cooling/#findComment-8208449
Using liquid nitrogen someone reached 5.7 GHz. So yeah it might be possible. But I guarantee you it will not be practical nor financially justifiable in virtually any case.
To RGB, or not to RGB? That is the question.
- Shakespeare. Hamlet, Act III, scene I.
https://linustechtips.com/topic/635972-phase-change-cooling/#findComment-8208452
