Hot 980
7 minutes ago, GreenOnion said:We use AC in the house so it always around 26-28 Celsius.
Yeah, so your temps check out if I'm honest, that's what I'm seeing online. Just get rid of "Force Constant Voltage". Do a quick stress test on something (imo, if you have it, The WItcher 3 is probably still one of the most stressful games out there), and if your temps are still between that 37-80C range, you're fine. It's pretty consistent with what I'm seeing online too. I mean, it's a pretty fat card, but it still "just" has 2 fans, so it's a fairly reasonable temp range for a factory overclocked 980. I would recommend a more aggressive fan profile like Imakuni said, if you can stand the extra noise. It will help you stay below your temp target and eliminate any throttling too.
TL;DR I wouldn't worry, you're fine.
