On 7/31/2016 at 9:18 AM, Naveronasis said:
Im trying to find a set top box to stream netflix/hulu/youtube but I also want one with a coax in that can tune over the air digital (in the US if that matters). Anyone know of one?
There aren't any set top boxes with coax in. Typically you can find all of this in a television (apps and cable inputs).
TiVo makes such a device but with no support for Hulu. I think an HTPC is a neater option though (and allows you to run without a subscription).
