Just finished my computer build, but only now is it that I have hit my first bump in the road.
So, my computer, right now at least, only has HDMI and DVI-D Dual link video outs. Now, the only spare computer monitors around right now (didn't have enough money to get a new monitor) are a television which will need to be returned to it's original purpose when I'm done with it anyways, and an office monitor that has DVA and most importantly, DVI-D dual link inputs. The only problem I am finding, is that I don't have any DVI-D dual link cables. I actually have 2 DVI-D single link cables.
My question is whether or not I can use my DVI-D single link cable, albeit at a lower capacity than dual link, to carry the video signal?
https://linustechtips.com/topic/635216-help-dvi-cable-question/
You can, believe single link is maxed at 1920x1200 at 60hz
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/635216-help-dvi-cable-question/#findComment-8200162
yeah It will work.
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/635216-help-dvi-cable-question/#findComment-8200180
9 minutes ago, positivePXL said:
You're a live-saver, mate,
:D
:D
 I can't used hdmi on my monitor because the colours are shit.
https://linustechtips.com/topic/635216-help-dvi-cable-question/#findComment-8200226
