Hey guys. that time has come again where i need to reformat.
I normally use DBAN and wipe my SSD then reinstall windows only problem is, last time i did that some programs had some cache on my 1TB scratch disk so when i reinstalled said programs they freaked out so i had to wipe my scratch disk also.
it took in all around 2 days. i cant afford to do that again and i have tons of pictures on my scratch disk now.
so my question is
Can i just unplug my HDD, boot into Windows, then "reformat" my SSD through DiskManager which would essentially wipe it right?
Will it fully clear my SSD?
thanks guys,
John
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/63495-reformatting-help/
Just plug the SSD into another computer and format from there.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/63495-reformatting-help/#findComment-868480
why would that be any different than me doing it from my computer?
https://linustechtips.com/topic/63495-reformatting-help/#findComment-868489
Wiping within Windows is always a pain in the ass.
https://linustechtips.com/topic/63495-reformatting-help/#findComment-868493
would i risk corruption or is it next to impossible?
i dont mind tinkering a little.
it would be easier for me to do it through windows unfortunately
https://linustechtips.com/topic/63495-reformatting-help/#findComment-868501
Unless the program is insanely well coded, I'd think it's impossible. Windows has files it doesn't want you to be wiping, and puts up a hella lot of walls to do just that.
https://linustechtips.com/topic/63495-reformatting-help/#findComment-868509
...you DBAN a SSD?
ya....
https://linustechtips.com/topic/63495-reformatting-help/#findComment-868525
is this my best option then?
http://www.corsair.com/applicationnote/secure-erase
https://linustechtips.com/topic/63495-reformatting-help/#findComment-868535
If you have a Corsair SSD, I'd use it.
https://linustechtips.com/topic/63495-reformatting-help/#findComment-868545
stop
shouldn't be necessary
i had some viruses and a buncha crap and pretty much wanted a surefire erase...it worked and luckily havent seen a performance droop
never again though...i can quit whenever i want
PartedMagic is opensource
i was wondering if you had heard of it
i guess i'll try it this weekend
https://linustechtips.com/topic/63495-reformatting-help/#findComment-868550
