Phone connection issues
Solved by rob3342421,
So everything is fixed! I did not fix it, instead the recent update to the 1607 build has fixed everything!
Which means that the problem was with Windows in the first place and their attempt to get money out of me for tech support was unfair!
Still, I'm happy that it is sorted! Sorry if you're looking for an answer but mine was sorted with the summer update!
