Posted July 29, 2016 Please feel free to write an explanation. Link to comment https://linustechtips.com/topic/634422-do-i-need-a-shock-mount/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 29, 2016 A shock mount prevents vibrations and noise coming to the microphone like if you accidently hit your desk, or the boom arm, so you may want to get it if you can find one for cheap. Link to comment https://linustechtips.com/topic/634422-do-i-need-a-shock-mount/#findComment-8192308 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2016 There are ebay shock mounts or other ones from music stores for very cheap, they would be important for you I guess since there's keyboard claks and mouse clicks and movements and arm movements on the desk, so the shock mount will mitigate those vibration from traveling to the mic. Keyboard claks especially are pretty annoying... www.shawngmusic.com Link to comment https://linustechtips.com/topic/634422-do-i-need-a-shock-mount/#findComment-8198951 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2016 you dont need a very expensive shock mount, if you find a cheap one, go for it. but just be careful not to bump your desk/mic when recording. Also, what mic do you have? Link to comment https://linustechtips.com/topic/634422-do-i-need-a-shock-mount/#findComment-8199376 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 8, 2016 Author On 7/30/2016 at 5:43 AM, dorirot9 said: you dont need a very expensive shock mount, if you find a cheap one, go for it. but just be careful not to bump your desk/mic when recording. Also, what mic do you have? going for a snowball Link to comment https://linustechtips.com/topic/634422-do-i-need-a-shock-mount/#findComment-8254471 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 8, 2016 You won't need one, but it will improve minor vibration sounds. i'd say wait a while and if people complain about audio get one. and if you want one because you can get one, get a cheap one Link to comment https://linustechtips.com/topic/634422-do-i-need-a-shock-mount/#findComment-8254518 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
