What is the tubing and fitting sizes for a G1/4 block?
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/63401-stupid-question-need-help/
1/4" refers to the thread size,it doesnt refer to tube dimension.
As long as the thread is 1/4" on the fitting and the the tube matches the fitting size (for compressions) then you are golden.
You only need to match the ID of the tube for barbed fittings
SR-2-2x X5650 Xeons-3x 670 FTW-1x 120Gb Force GT-1x 240Gb Force GT-1tb WD Green-12Gb Dom GT 1866-Platimax 1500w-2x HK3-2xD5-24v controller-3x RX 480's-3x NiBlk HK GPU blocks-Koolance tops-BP res-15x SP120's-Little Devil V8.
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-867157
So 1/4 ID?
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-867176
So 1/4 ID?
No.
Example 16OD/10IDmm tube requires a 1/4" thread fitting with a 16/10 compression size OR a 1/4" thread 10mm barb.
The bit that screws into the block is BSPP 1/4",the rest of the sizing depends on the tube.
3/8" was once popular,1/4" is now the standard thread size for all WC gear,only some Eheim pumps and the PA series rads from thermochill still use odd sizing fittings now
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-867199
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-867209
1/4" is the standard sized thread for all common fittings and water-cooling components. Most fittings have G1/4 threads. You can choose any tubing size you want to go with when you pick the fitting.
I would recommend;
3/8 ID 1/2 OD
or
3/8 ID 5/8 OD
as they are the most popular sizes and have the most fittings.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-867222
I would recommend;
3/8 ID 1/2 OD
or
3/8 ID 5/8 OD
Thanks
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-867230
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-867233
I would recommend;
3/8 ID 1/2 OD
or
3/8 ID 5/8 OD
The top fitting requires 10m ID tube
Second is 7mm ID tube.
Third is 13mm ID tube.
Will this work? https://docs.google.com/spreadsheet/ccc?key=0Av5XWiVAEO0ydERlZjNVcC1SUGw3ajVZQnNPdFB5SXc&usp=sharing
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-867357
  • You forgot to include tubing
  • You are using a cheap pump. I would opt for a Laing pump if I were you.
  • You are using a pump+res combo with an EK pump inside, so you are effective adding 2 pumps to the loop.
Make sure the Xbox 360 has a 12V power rail and can take the additional load of the pump and fans on the PSU. Otherwise the PSU will fail.
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-867383
Ill be using an external power source, so thats not a problem. Ill be using that primo-chill tubing, and the combo does not include a pump.
Also, I would have to use barb fittings if I were to get a better pump
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-867391
you won't need to have barb fittings, as long as the thread size (1/4 prefferably) and the compression dimensions (usually found in description with what tube it's compatible with) then it will be fine
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-868842
You can buy a pump top for the Laing pumps, which have a G1/4 thread just like all your other components will.
https://linustechtips.com/topic/63401-stupid-question-need-help/#findComment-869717
