Keyboard Layout Help
Go to solution Solved by Flatnose321,
Just now, MrDrWho13 said:
Click English (United Kingdom) then options then you should see keyboard options.
i just did that and the problem was fixed. Thanks for the help
If you're on windows 10, go to start > edit language and keyboard options > set the country or region to UK
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/633468-keyboard-layout-help/#findComment-8179061
4 minutes ago, Flatnose321 said:
My keyboard is qwerty uk and for some reason it has randomly turned into us qwerty which is so annoying. I tried searching on the internet but all i found were for windows 7. So please help.
Are you on windows 10 or something else?
I edit my posts a lot.
https://linustechtips.com/topic/633468-keyboard-layout-help/#findComment-8179062
