1 minute ago, brodieslee said:
Have you tried putting it in RAID 0 with the E: drive? If you have, try installing ubuntu on it or something to make sure it isn't just corrupted data.
Oh yeah by all means, go install an entire operating system on it to check if it's corrupted as opposed to right clicking it and scan for errors like a normal person would
Blue screens eh? Did you try setting it to Wumbo?
I have 600 GB of data on it
Ubuntu 24.04 on Ryzen 5 5600x and GTX 1070
Mint 22 on Razer Blade i7-11800h and RTX 3070
how do you put it in raid 0
1 minute ago, Damocles said:
How do you have 600Gb of data on a drive only giving you 431.51 GB to use?
:) wrong drive it is disk 0 or the 3tb one
The e drive
Alright run CMD as admin and manually do this. Type in "diskpart" then "list vol", look for the volume that is 745.52 GB in size and remember that number. Type in "sel vol X" where X is the number you took. "assign letter Z" where Z can be any unused drive letter
I will try that
it doesn't show up
found this
I just bought a 4T HD and It has one partition and another part with unallocated space.. I can't create one partition for some reason.. I have tried partition manager and partition magic and no lock what can I do to turn this hd into just one partition??
More about : create partition unallocated space hard drive
Best solution
To create a partition of larger than 2 TB the drive needs to use a GPT partition table. What version of Windows are you running? If this is to be used as a storage drive, look for the option "convert to GPT disk" then delete the current partition and create a new one.
7 hours ago, Tyleredbowers said:
found this
Best solution
You're right, he's probably using MBR right now, but that doesn't explain why the partition won't show up in CMD. To be honest though...
it doesn't show up
I can't see sh1t! What did you screen cap this on? A freaking 99999k Monitor? That's so small Intel's 14nm process is jealous. Anyways, I think there's a program to convert MBR to GPT for system disks as I don't believe you can just convert it through windows if it's a system drive. Try EaseUs Partition Master, It works well and the interface is easy to use. Might need to pay however, so unless you wanna reinstall windows and lose your data, you'd have to Cough***Rough***Augh***Cough***Kugmm... Excuse me... pay for it
:) it is a 1080p monitor I am getting this one soon https://www.amazon.com/Dell-Gaming-S2716DG-LED-Lit-Monitor/dp/B0149QBOF0
and I did buy windows and I have the sticker But it didn't work (I paid full price)
