First Build! Suggestions?
Solved by Dresta,
Very well built build,nothing to change,as far as ram i dont see a problem and if there is a problem you just move the ram a slot to the right and there you go,good luck with your new build ![]()
DARTHDIVIDER0213 ·
Posted in Troubleshooting5 -
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
_Darasuum_ ·
Posted in Power Supplies6 -
1
4
anothertealtiger ·
Posted in Programs, Apps and Websites2 -
Mumintroll ·
Posted in Programs, Apps and Websites4 -
ElDTac ·
Posted in CPUs, Motherboards, and Memory3
play_circle_filled
Latest From ShortCircuit:
