Hello there friends !
Was wondering what a good case for the swiftech H320 is
I live in Australia so yeah ..
The case I was originally planning to use was a phantom 410 with a x60 , but seems like I might have to get a larger case to accommodate the H320, please not too expensive . I'd like to keep it under 200 Australian dollars , and please no super massive cases ( I.E 900D size case )
Thankyou in advancee :)
https://linustechtips.com/topic/63277-case-for-h320/
750D
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/63277-case-for-h320/#findComment-865075
Sweet, question , could I mount the rad on the top or would I have to mount it in the front and remove some drive bays ?
Top. It supports 3x120mm, front supports only 2x120/140mm.
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/63277-case-for-h320/#findComment-865108
Corsair Air 540, an excellent case that fits the H320.
https://linustechtips.com/topic/63277-case-for-h320/#findComment-865129
