If the laptop is sluggish, add an SSD. 8 GB RAM is more than enough for most laptops. Unless you want a RAM disk in which case, don't.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
14 minutes ago, JWOC said:
does anyone know if you can upgrade the RAM in a lenovo flex 3? i have 8 gigs of DDR 3 and want to upgrde to 16 gigs of DDR 3.
Are you doing something so RAM intensive but not cpu/gpu intensive that only adding RAM would drastically improve your performance? o_O
The thinner laptops are probabl at their maximum capacity already and can't be added to.
  • 1 month later...
24 minutes ago, JWOC said:
i play Kerbal space program mainly and it is very slow because of what it has to render and  the 8 gigs i currently have make it quite slow. sorry for taking so long to respond.
-JWOC
Check the manufacturer's website for the model. Some laptops are limited by their BIOS.
-JWOC
