I own a acer aspire M5-583P-6432 and something is wrong with it. I used it for about a year and it worked great until one day I shut it down and turned it back on the next day, and the acer loading screen popped up and after that the screen went blank. I solved this issue by letting it sit for awhile and it would work perfectly. But now it doesn't work at all, it has the same issue and after letting it sit for hours and it still doesn't do a thing. I had my dad look at it and he successfully upgraded to windows 10 and deleted all my data, and it worked for awhile then I restarted it and it has the same issue again. Anyone know any fixes? We think the issue has something to do with the video card. Thanks!!!
https://linustechtips.com/topic/632532-help-pls/
did you drop it at some point
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/632532-help-pls/#findComment-8165628
17 hours ago, Paarthri said:
Alright, get to your bios menu and show me your boot list. If you don't know how to do this it is laptop specific so Google is your friend.
Ok... Well last night before I saw your message I hooked it up to my t.v via HDMI and it worked somehow. It was really weird because my dad hooked it up to his monitor a long time ago and that didn't work... So problem solved? I'm going to try the bios thing too though, just in case.
https://linustechtips.com/topic/632532-help-pls/#findComment-8189339
No don't worry about the bios. Does the Asus logo still come up when it is connected to the tv? Also, was the old monitor vga?
https://linustechtips.com/topic/632532-help-pls/#findComment-8189491
well i used a laptop so it was always connected and the acer logo only comes up once and awhile and i'm not sure if it shows on the t.v, I will go test it right now.
https://linustechtips.com/topic/632532-help-pls/#findComment-8219204
Ok update, I turned on the laptop and it had the acer logo and it didn't show up on the t.v or screen, so I closed the screen and opened it back up, which had the same results. So I mashed the enter key and it showed up on the t.v and screen for some reason. I don't know why... Maybe I was in the bios screen but it didn't show up. I also was playing a couple of games and the graphics card stopped working. So I am really confused. PLEASE HELP
https://linustechtips.com/topic/632532-help-pls/#findComment-8219261
Could be a drivers issue.
Go to Device Manager and update your drivers. What graphics chip are you using?
If its integrated here are instructions: https://support.microsoft.com/en-us/instantanswers/ad5a063e-5f57-c715-2566-b983195752c1/update-drivers-in-windows-10.
If its nvidia or amd go to there websites to get drivers.
https://linustechtips.com/topic/632532-help-pls/#findComment-8220838
nope didn't work.
https://linustechtips.com/topic/632532-help-pls/#findComment-8225769
