http://pcpartpicker.com/list/wLFGcc
Can't wait!
Gonna customize the case and stuff probably.
Thinking Black/Yellow w/ white accents.
It gon be hella finna.
Mathresolvermajig: Intel Core 2 Duo E8400 @ 3GHZ
Framepainting-inator: EVGA GT 730
Attachcorethingy: ¯\_(ツ)_/¯
Infoholdstick: 4x2GB sticks
Computerarmor: Lenovo Case
Rememberdoogle: 2 250 Gig Drives
AdditionalPylons: Generic 300 Watt
Letterpad: Lenovo
Buttonrodent: Lenovo
Aural Interface: Sony
Liquidrectangles: 1 1600x900 Vizio TV
https://linustechtips.com/topic/632046-next-build/
[REAL] Artist render of my new PC
Letterpad: Lenovo
https://linustechtips.com/topic/632046-next-build/#findComment-8160556
Only thing Id ask is if you plan on upgrading your CPU to a K series ever. If so I'd say spend a little bit more on a Z series Motherboard. Otherwise it looks like a solid build!
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/632046-next-build/#findComment-8160565
Not at the moment, I'd rather not OC anytime soon.
Thanks for the suggestion though!
Letterpad: Lenovo
https://linustechtips.com/topic/632046-next-build/#findComment-8160568
Just now, DrMikeNZ said:
I hope you are better at using paint than you are at using Paint.
Hah, yeah.
https://www.blankmindscomics.tumblr.com
Letterpad: Lenovo
https://linustechtips.com/topic/632046-next-build/#findComment-8160574
