I have plans to buy a Eclipse P400 case from Phantek and I want LEDs for it, I'm from Australia and I was told that the phanteks LEDs arnt to good. I was wondering what other options there might be. (Hopefully from Mwave, MSY or eBay)
Thanks
Intel Core i7-6700K 4.0GHz Processor / Cooler Master Hyper 212X LED Cooler / ASUS Maximus VIII Hero Z170 Motherboard / TeamGroup Nighthawk 16GB (2 x 8GB) DDR4-3000 Memory / OCZ Trion 150 480GB 2.5" Solid State Drive / 2x WDBlue 500GB 2.5" 5400RPM Hard Drive (Raid 0) / EVGA GeForce GTX 1060 6GB SC GAMING Video Card / Cougar Panzar Duel Window ATX Mid Tower Case / SeaSonic 520W 80+ Bronze Fully-Modular ATX Power Supply / Microsoft Windows 10 Pro
https://linustechtips.com/topic/631925-phanteks-eclipse-p400-led-strip/
We had requests from customers asking for us to make Phanteks LEDs as the phanteks ones are not good and no where else made compatible LEDs, so we now make a compatible kit for their cases. As far as we can tell we are the only store/manufacture that makes them.
You can find them listed on our store here - https://addoncustoms.com/store/product/77-phanteks-compatible-rgb-lighting/  - Comes with a black PCB, extra strong sticky back foam and a sleeved cable on both ends. There are 1 meter and 2 meter options.
Happy to answer any questions you may have. :)
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
The price that your selling them for come to about $28AUD (not including whatever postage is) and I didn't allow more than $20AUD.
Unless it was possabe for me to get them for under 20AUD then I don't think I'll be getting them. Maybe if there was a sale or discount.
The Phantek led strips, what's wrong with them? If it's just mounting them I might beable to find my own fix somehow.
I have only handled 1 set of their LEDs, as I had to work their wiring so I could make ours. First issue was locating a set, every store I found was sold out, when I finally did get a set the wires that were soldered onto the strip snapped off and I was barely touching it, this rendered the whole set dead. (but got the info I needed)
If you do go with a official Phanteks set, try not to move the wires as they may break.
But we got requests to make them because apparently the LEDs died out quickly and the sticky was bad (but the sticky is bad on pretty much every LED strip unless they use foam) I cannot comment on the LEDs as our phanteks set has never been on for more than a few minutes. but if the phanteks LEDs do die out that should be covered by their warranty, so they should either fix or replace them
Addon Customs -
