Hi guys,
so I am planning to re do my home net work from the standard ISP network and I am searching for a Acces Point under 150 Euro
So my planned Setup will look like this:
ISP --> Modem(Combo from ISP, which is put in Single User mode so its only a modem) --> Load Balancing Rouder (Output of Switch are only 100Mbit)--> Gigabit Switch --> Acces Point / PC/ NAS/ SERVER ...
Thee only thing I need is the acces point, so I am asking you guys for your recommandation, and how Improving setup, if its necessary.
Thankufll Chris
Intel i7 5820k - MSI X99A SLI Plus 3.1- HyperX Furry 2666Mhz - MSI GTX 970 - Intel 730 250Gb and 3 TB WD RED - RM650i - H440 Red Black
https://linustechtips.com/topic/631781-acces-point-recommendation/
I don't entirely understand your setup but from the looks of it you aren't doing anything too serious.
I personally use the Xclaim Xi-3. I Don't know if it supports zero hand off but the range is good enough that you should likely only need one
amazon: https://www.amazon.com/Xclaim-Dual-Band-802-11ac-Indoor-1-167Gbps/dp/B00Q5PG3KA
18 minutes ago, JaredM54 said:
I like my Ubiquiti APs, take a look at their AC line.
1 hour ago, Feanyest said:
Hi guys,
Thankufll Chris
Like Jared said, check out the Ubiquiti UAPs. They have 3 models, and the UAP-AC-PRO would fite fine within your budget. As the router, I would also recommend getting an edgerouter lite. It can do 1m PPS, and is only $99 USD.
My native language is C++
11 hours ago, Feanyest said:
You guys know you are way over my maximum price ^^? But thanks for the ongoing help
https://www.amazon.de/Ubiquiti-UniFi-AP-AC-PRO/dp/B016XYQ3WK/ref=sr_1_1?ie=UTF8&qid=1469677897&sr=8-1&keywords=uap+ac+pro
Get the Pro, its way better than the Lite.
For reference though, the Lite is better than every other consumer router/AP I've ever used...
