Okay so, whenever i press the shift key after some time not typing, there will be a delay before it respond, like i can press shift a couple times and it will not work, then i will press it, it will start working and it will work super fine for a while as long as i keep using it. then if i stop using it for a while, the problem will occur again.
Also i realized that shift+t and shift+y will not make capital letters while all the others work fine.
QWERtyUIOPASDFGHJKLZXCVBNM       they work fine with caplock tho, TY
it has nothing to do with the keyboard settings in windows, drivers are up to date as far as i know (trought windows 10)
y510P lenovo laptop.
https://linustechtips.com/topic/631470-keyboard-problem/
