Turn off Strix 970 white power led?
Saiyan
It's just a tiny LED just above the pcie cable that stays on as long as the card is recieving power even when the PC is shut down. Want to know if anyone had a fix in software that turns this off so I can route my cable a different way without having it shining out of the case.
PCPartPicker: z97 Gaming 5 | 750w Photon | 850 Series 250gb SSD | Phanteks Enthoo Pro | LG25um56-P | Corsair K70 RGB | Asus Strix 970 4gb | WD Blue 1TB | Logitech G502 | i7-4790k | H100i GTX w/ (Noctua NF-F12's) | HyperX Fury Black 1x8gb 1866 | NZXT Hue+ |  ATR2500 | ATH-M50x |
Clip it and replace with a resistor of the same load?
Mathresolvermajig: Intel Core 2 Duo E8400 @ 3GHZ
Framepainting-inator: EVGA GT 730
Attachcorethingy: ¯\_(ツ)_/¯
Infoholdstick: 4x2GB sticks
Computerarmor: Lenovo Case
Rememberdoogle: 2 250 Gig Drives
AdditionalPylons: Generic 300 Watt
Letterpad: Lenovo
Buttonrodent: Lenovo
Aural Interface: Sony
Liquidrectangles: 1 1600x900 Vizio TV
That is Normal. Asus card LEDs don't turn off. If the LED turns of that is bad.
Wouldn't a small piece of electrical tape over it suffice?
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
  • 6 years later...
GeForce Experience's 'LED Visualizer' (on older versions) seems to have been the solution back in the day but no longer available on newer versions of GeForce Experience.
The back up plan is bluetack or a small piece of electrical tape - or do your research and buy a newer card that doesn't have any annoying LED's.
I'm only just replying now because I just built my new pc with glass side panel and noticed it and am repurposing my old GTX970 till I can afford a new card.
