Power Supplies
Go to solution Solved by STRMfrmXMN,
2 hours ago, blackwargraymon said:
Hello,
which Power Supplie(modular) will be great for the bitfenix phenom m micro-atx case?
I need a Supplie with short cables. From 550W to 600W.
Thank you for the replies.
The EVGA GS is a perfect fit for that case, I've built in one before.
SeaSonic M12II EVO 520W is a good value option
https://linustechtips.com/topic/631312-power-supplies/#findComment-8152157
Hello,
https://linustechtips.com/topic/631312-power-supplies/#findComment-8152709
