Saitek X52 Pro. Joystick action works, buttons do not.
atled
Hello everyone. So I have the HOTAS system. The left hand throttle works 100% fine. Buttons, mini-stick and all. The joystick however has issues. The action of yaw, pitch, and roll work 100% of the time. The buttons like the trigger and the hat switch do not work. Well, most of the time. If I hold the trigger down, some buttons will work some of the time. Other times they'll be stuck in the on position even when not being pressed. Even more odd is that the three switches on the bottom work all of the time! I'm so confused as to why it would work sometimes if the trigger is being held down.
Thoughts?
The Unit might be broken, that or some settings for the button functions aren't configured.
