Ok so this is my new build and i recently got a fella to pick the parts and he came up with this....
http://uk.pcpartpicker.com/p/1G9Al
I was wondering does everything fit properly and will it be good for games such as battle Field, Farming Simulator and other games at a high FPS rate and on Ultra settings.
Could i get anything better with my money or is that final
Thanks anyway.....
https://linustechtips.com/topic/63087-my-first-build-need-help/
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  (£109.19 @ Aria PC)
CPU Cooler:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£23.98 @ Scan.co.uk)
Motherboard:  Gigabyte GA-970A-UD3 ATX AM3+ Motherboard  (£71.96 @ Scan.co.uk)
Video Card:  Sapphire Radeon HD 7970 3GB Video Card  (£231.09 @ Amazon UK)
Total: £672.84
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-10-06 21:39 BST+0100)
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/63087-my-first-build-need-help/#findComment-862109
Memory:  G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory  (£76.03 @ Amazon UK)
Video Card:  Asus Radeon HD 7970 3GB Video Card  (£301.73 @ Amazon UK)
Total: £688.97
(Generated by PCPartPicker 2013-10-06 21:32 BST+0100)
Lol what? who pays £76 for 8gb of ram on a budget build?
Every 60 seconds in Africa...
A minute passes.
https://linustechtips.com/topic/63087-my-first-build-need-help/#findComment-862134
Total: £688.97
What better performance would i get out of this new set up.
https://linustechtips.com/topic/63087-my-first-build-need-help/#findComment-862136
I just notice that -_-
https://linustechtips.com/topic/63087-my-first-build-need-help/#findComment-862138
Umm you get a 7970 instead of a 7950 which will be better for gaming if your gaming with is
https://linustechtips.com/topic/63087-my-first-build-need-help/#findComment-862152
GPU is better, but it's more expensive and it doesn't include Windows. If you can stretch your budget a bit, it will be better to get the 7970, but the 7950 is fine if you want to keep it lower budget.
Stick to the PNY RAM, 8Gb 1600Mhz CL9, what else do you need, RAM is RAM after all :P
https://linustechtips.com/topic/63087-my-first-build-need-help/#findComment-862153
Exactly what would i benifit from getting a SSD..
What performance would i get out of it and what is it exactly :P
The hdd is the slowest part in your system and is the biggest bottleneck. Getting a ssd helps relieve that and everything becomes smoother from opening your applications to how smooth your browser is by removing a large chunk of your hdd's seek time.
In short, it's the best part upgrade you can make for the money.
As for your build, it looks fine.
https://linustechtips.com/topic/63087-my-first-build-need-help/#findComment-862187
