i am trying to build a custom pc case with a micro atx motherboard that i have laying around with an i7 3770k and 32gb of ram. i need a lower profile cpu cooler (i have intel stock coolers) that can be shorter and passively cooled by the single fan which will be ducted to the cpu cooler. can i just cut a hyper t4 in half (i have two laying around)? my only concern is with the heat pipes and i thought that they were solid copper but then i thought that i heard that they were filled with a liquid/gas that helps with heat transfer up the pipes which makes sense. i would rather not ruin  a cooler if if its in the name of science.
has anyone tried this? is this a good idea?
let me know what your think and ill try some of them out.
https://linustechtips.com/topic/630573-modify-tower-cooler-hyper-t4/
just get this https://www.amazon.com/Cryorig-CR-C7A-Flow-Heatsink-47mm/dp/B0177GTV9U/ref=sr_1_3?ie=UTF8&qid=1469160277&sr=8-3&keywords=
M1 MacBook Air 256/8 | iPhone 13 pro
And to answer your question, yes heat pipes contain fluid.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
Heatpipes work off the principle of phase transitions.
The reason why heatpipes are desirable is not because of just their thermal conductivity, but their ability to transfer that heat somewhere else. By cutting the heatpipe and removing the fluid, you would be reducing the efficacy of the cooler fairly significantly. Copper is a fantastic conductor of thermal energy, but it can't transfer it well. Tack onto this the fact that your new cooler would have a lower relative density in which to transfer that heat, and you'll find that a hacked apart heatpipe will perform significantly worse than the stock heatsink.
33 minutes ago, GreezyJeezy said:
really?
Yes.
