Hello about 3 months ago my iPhone broke after the charger blew while I was charging it, the charger plug and the end tip (USB) in the plug turned black, don't know if that helps at all.
I have decided I want to try and fix the phone I have got a brand new working lighting cable and a plug that definitely works. This is what I've been told to check in posts like this.
http://www.payetteforward.com/my-iphone-wont-charge-heres-the-real-reason-why/
It's not a software crash, it's not a dodgy or broken cable, it's not a bad power source and as for inspecting the charging port, there are no bits inside it. Also, this iPhone had a battery replacement about 3 weeks before the charge broke it whether this is related to the problem I'm having now I don't know. That's about all I can tell you. I don't think it could be the battery, could it? But if anyone can tell me what it could be that would be very helpful, thanks!
https://linustechtips.com/topic/630351-iphone-5c-charging-problems/
What charger were you using before? The one that blew up. If it's a cheap aftermarket one... could be bad.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
As far as I can remember the cable was a £1 cable so cheap but as for the plug i believe it was a official apple one, i don't see how the cable could causes this or do a lot of damage can it?
