Question about CoolerMaster MasterAir Maker 8
Go to solution Solved by LogicalDrm,
15 hours ago, pwn_intended said:
The LED's appear to be built into the fan shroud. And the fans are not standard so putting on aftermarket fans would have to be done with duct tape (or whatever other DIY method you like)
Manual shows that it comes with brackets if one wants to use another set. But this is one of those coolers you buy for the package, not parts.
When in doubt, re-format.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
