Ok so I I was putting in new ram so I turned my pc off and grounded etc and then put in the new stick I turned it back on and there was then no picture at all, there is power to my gpu and cpu as the fans have been going.
So I few days later me and my friend decided to troubleshoot and we used New ram - didn't fix it
New gpu - no fix
We reset Bios - no fix
Checked every connection and checked power supply all were fine to we even swapped out monitors and cables and it made no difference.
Ok so I just retested both ram in all 4 slots - Total number of combo's 9
but atlas no change signal.
 also took all apart and rebuilt still no change
I checked cpu all is intact and thermel paste has been applied evenly still no change.
However we couldn't try another cpu as we had none . All I was doing was putting  in a new stick of ram so I have no idea why it's not working, Does anybody know how to solve this problem.
Is it mother board?
https://linustechtips.com/topic/630192-pc-not-working-help-please/
Just now, OVD1234 said:
maybe its the MB can you share your System Specs (before and after)
<<<< Dont mind this picture
Before I had
Motherboard: Msi 970A-G46
Gpu: Zotac 4gb GDDR5 GTX 960
Cpu: AMD FX-8350 4GHZ 8- Core Processor
Ram: 4GB Ram DDR3
PSU: Corsair VS650 ( 650 watt )
After
Ram: 8GB Ram DDR3
I only added one stick of the exact same ram
its maybe that the ram caused something on the motherboard like a circuit or copasitor (i dont know how to spell it)
is blowed up and how did you put ram in 2 in the blue/black or 1 in blue and 1 in black?
2 in blue
and I tried 2  in black
Then I took each on i tried them in every slot 1 at a time to see if one was faulty but nothing happened
so my friend brought up his new ram and we tried that and we new his worked in another pc however we got exact same results. Which was no screen signal/boot up or anything.
