Hi, Recently i have upgraded to the nexus 6 and i nolonger use my old moto G gen 3, I was going to sell it for some spare cash but i cant get it to flash and lock the bootloader with stock firmware, ive been at this for a couple of days and all the forums i have read (i looked at as many as i could on several different sites) i couldnt find the answer as they will come with the issue and it would never be resolved. On to the issue;
this is what i have been using to attempt to reflash and lock my phone, yes i have tried mfastboot aswell.
adb reboot-bootloader
fastboot oem lock begin
fastboot oem fb_mode_set
fastboot flash partition gpt.bin
fastboot flash bootloader bootloader.img
fastboot flash logo logo.bin
fastboot flash boot boot.img
fastboot flash recovery recovery.img
fastboot flash system system.img_sparsechunk.0
fastboot flash system system.img_sparsechunk.1
fastboot flash system system.img_sparsechunk.2
fastboot flash system system.img_sparsechunk.3
fastboot flash system system.img_sparsechunk.4
fastboot flash system system.img_sparsechunk.5
fastboot flash system system.img_sparsechunk.6
fastboot flash modem NON-HLOS.bin
fastboot erase modemst1
fastboot erase modemst2
fastboot flash fsg fsg.mbn
fastboot erase cache
fastboot erase userdata
fastboot erase customize
fastboot erase clogo
fastboot oem fb_mode_clear
fastboot oem lock
fastboot reboot
what seems to be the problem is when i do a "normal" flash of the stock rom everything works though if i try to lock it the system fails
C:\adb>fastboot oem lock begin
(bootloader) Please fully flash the signed build before locking phone!
OKAY [  0.364s]
finished. total time: 0.365s
C:\adb>fastboot oem fb_mode_set
OKAY [  0.010s]
finished. total time: 0.011s
C:\adb>fastboot flash partition gpt.bin
target reported max download size of 268435456 bytes
sending 'partition' (32 KB)...
OKAY [  0.007s]
writing 'partition'...
(bootloader) Preflash validation failed
FAILED (remote failure)
finished. total time: 0.416s
C:\adb>fastboot flash bootloader bootloader.img
sending 'bootloader' (2546 KB)...
OKAY [  0.089s]
writing 'bootloader'...
(bootloader) flashing sbl1 ...
(bootloader) flashing aboot ...
(bootloader) flashing tz ...
(bootloader) flashing hyp ...
(bootloader) flashing rpm ...
OKAY [  1.749s]
finished. total time: 1.840s
C:\adb>fastboot flash logo logo.bin
sending 'logo' (1352 KB)...
OKAY [  0.049s]
writing 'logo'...
OKAY [  0.128s]
finished. total time: 0.180s
C:\adb>fastboot flash boot boot.img
sending 'boot' (16384 KB)...
OKAY [  0.529s]
writing 'boot'...
OKAY [  1.312s]
finished. total time: 1.843s
C:\adb>fastboot flash recovery recovery.img
sending 'recovery' (16484 KB)...
OKAY [  0.529s]
writing 'recovery'...
OKAY [  1.284s]
finished. total time: 1.815s
C:\adb>fastboot flash system system.img_sparsechunk.0
sending 'system' (238438 KB)...
OKAY [  7.641s]
writing 'system'...
(bootloader) Invalid signed image
finished. total time: 8.095s
any ideas?.
https://linustechtips.com/topic/629598-help/
On 21/07/2016 at 4:53 AM, yurias said:
Why not body reply to this. Can any body help us ?
its ok, the moto g 3 is a tricky phone to mess with, ive had allot of phones rooted flashed ect and its mostly straightforward though this has proved to be the complete opposite.
https://linustechtips.com/topic/629598-help/#findComment-8158237
