Hi, a while ago today I was trying to reinstall my old gpu as a secondary gpu for physX to see if it would benefit me in any way even if just a boost of 2 to 3 frames. Thing is I found that my power supply only has 2 PCI-E 6+2 pin connectors.
My question is would it fix the issue if I manage to get a cable that would "double" one of the connectors so that I'd have sort of 3 connectors?
Would I find any issues with the wattage or are the 750W I have enough?
Would I find any other issues and is it worth to have the physX done in the gtx 550ti (which is my old gpu which I intend to place now) instead of the 780ti doing everything?
My rig is kind of the following except the PSU is a NOX Urano VX 750W and not a hummer, and the case is not the VX but the NOX Coolbay TX.
https://linustechtips.com/topic/629591-enough-power-for-2nd-gpu/
According to a review of your PSU which I had to translate from Spanish, your PSU is probably suited to single GPU systems best. 750W is most definitely enough wattage but an EVGA 750B2 would sooth my nerves about the worry of putting an off-brand PSU in a system with two GPUs.
https://linustechtips.com/topic/629591-enough-power-for-2nd-gpu/#findComment-8134256
