Hard Drive failiure?
Go to solution Solved by MrDrWho13,
Aaaaannddd you're screwed.
Stop using it immediately. Get a new drive and install your OS on that. Then try to recover as much as you can before it completely dies. You might want to do a checkdisk but that might kill it.
Is my hard drive close to die?
Röst 017_001.m4a
Yestureday i got a little bit angry and i hit my laptop and right when i did that, i started to hear a louder than regular noise that the hard drive does when it is "reading/writing"
and Today when i tried to start skype, It wouldn't start and tried to Restart the laptop but it did not work so i force shut it off by holding the on button, after that When i start my laptop it goes into "Auto repair mode" and keep's failing.
CPU: Intel i7 8700k
Motherboard: Asus ROG Strix z390-f
RAM: Hyperx
GPU: Asus rtx 2080 8gb OC
Case: Kolink observatory rgb
HDD: x1 Seagate HDD x2 Hitachi HDD
PSU: 500W something
Monitor: x1 HP Compaq LA2205wg 22 Inch
Fan's: x4 kolink fans
Keyboard: Corsair k55 rgb
Mouse: Trust Gxt
Headphones: Razer Kraken 7.1 chroma Headsett
Os: Windows 10 home
https://linustechtips.com/topic/629555-hard-drive-failiure/
Röst 017_001.m4a
gg hard drive
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/629555-hard-drive-failiure/#findComment-8130857
I edit my posts a lot.
https://linustechtips.com/topic/629555-hard-drive-failiure/#findComment-8130876
Agreed.
https://linustechtips.com/topic/629555-hard-drive-failiure/#findComment-8130879
Röst 017_001.m4a
You should definitely back up anything you need NOW!
https://linustechtips.com/topic/629555-hard-drive-failiure/#findComment-8130891
I just my mom just bought me x1 WD 1t byte hard drive and x1 Corsair 240gb SSD
CPU: Intel i7 8700k
RAM: Hyperx
PSU: 500W something
Mouse: Trust Gxt
Os: Windows 10 home
https://linustechtips.com/topic/629555-hard-drive-failiure/#findComment-8131840
  • 6 months later...
Gonna be a jerk and bump this thread by saying that my hard drive is still working and i still don't know how to transfer my os to the new ssd :P
CPU: Intel i7 8700k
RAM: Hyperx
PSU: 500W something
Mouse: Trust Gxt
Os: Windows 10 home
https://linustechtips.com/topic/629555-hard-drive-failiure/#findComment-9328045
