Hello. I need help building a pc since I am switching over from console gaming I don't need anything but the pc and I want to spend around $600-650 in USD I am looking to play games like bf4,rome 2,starcraft 2 , indie games etc. I am probably going to wait until amd's new gpu's come out so you can use them thanks
https://linustechtips.com/topic/62899-first-pc-build/
CPU:  AMD FX-6300 3.5GHz 6-Core Processor  ($119.99 @ Newegg)
Motherboard:  MSI 970A-G43 ATX AM3+ Motherboard  ($72.91 @ Newegg)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.98 @ Outlet PC)
Video Card:  PowerColor Radeon HD 7950 3GB Video Card  ($179.99 @ Newegg)
Case:  Cooler Master RC-430-KWN6 ATX Mid Tower Case  ($29.00 @ Newegg)
Power Supply:  Corsair CX 600W 80 PLUS Bronze Certified ATX12V Power Supply  ($54.99 @ Microcenter)
Optical Drive:  Lite-On iHAS124-04 DVD/CD Writer  ($14.98 @ Outlet PC)
Operating System:  Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($85.87 @ Outlet PC)
Total: $651.32
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-10-06 01:01 EDT-0400)
This is if you need an OS, and no peripherals. We need more information here...
https://linustechtips.com/topic/62899-first-pc-build/#findComment-859348
Not sure about the GPU price but here http://pcpartpicker.com/p/1Lolm
If you need Windows http://pcpartpicker.com/p/1Lonw it's a bit over budget though
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/62899-first-pc-build/#findComment-859359
Total: $651.32
No I don't need the OS or peripherals
https://linustechtips.com/topic/62899-first-pc-build/#findComment-859372
all of there prices are confirmed but the 290x
Then that build is good I think. The extra $30 could be used to buy a cooler like the Hyper 212 EVO.
https://linustechtips.com/topic/62899-first-pc-build/#findComment-859388
thanks for the build I will probably post pics when done also is it normal that Im shopping for ram by color it feels stupid.
No it isn't stupid*, there's not much that differentiates RAM anyway as any performance difference isn't really noticeable (unless you're rendering video or something). Shopping for RAM by colour is what you should do.
Also you could switch out the R9 270X for a 7970 and switch the 8320 for a 6300 if the 270X doesn't perform as good as I think it does.
https://linustechtips.com/topic/62899-first-pc-build/#findComment-859414
No it isn't, there's not much that differentiates RAM anyway as any performance difference isn't really noticeable (unless you're rendering video or something). Shopping for RAM by colour is what you should do.
I did what you said and got gskill sniper series ram it goes good  with the case. thanks
https://linustechtips.com/topic/62899-first-pc-build/#findComment-859431
