Logitech Extreme 3D Joystick
Go to solution Solved by AlwaysFSX,
It's got a little flippy switch at the base. Love mine, most solid inexpensive joystick I've ever used.
Hey LTT forum users,
I want to pick up one of these joysticks to do some flight simming. However I don't know of this joystick comes with a throttle. If it does and anyone has one ca you please send me a pic of it?
Thanks
Do you play football/soccer?
Cause you look like a left-back
https://linustechtips.com/topic/628331-logitech-extreme-3d-joystick/
/thread right there :P
i still have an older logitech attack 3, its a bit flaky and the resistance on the axis is wearing out a bit, but dang are these lovely things to game with :P
I need to fix I believe the right rubber band for the rudder because it leans to the left and screws up my rudder a bit, other than that it's held up incredibly well over 6 years of use.
6 minutes ago, AlwaysFSX said:
Yup, it works a lot better than it looks, just be careful not to hit it while flying.
If the LTT FS community love it this much I'm in. Thanks for the help
Don't expect it to be the most amazing thing ever, because it's simply an affordable joystick. But it's solid and well thought out. I would buy it again in heartbeat.
