Help with GPU temps
By
Sean-
in Graphics Cards
in Graphics Cards
Solved by TrigrH,
okay, had to think about this one for a while, best solution:
get a super long flexible SLI bridge
+ a flexible PCIE riser.
and mount the card lower.
oh and BTW:
you are seriously damaging your motherboard separating the cards like that, REMOVE IT and underclock the gpus for now.
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
