3 minutes ago, bagusnl said:
if nortbridge is not hot enough to harm if you touch it, it will just fine. but if you want to, just add in a thermal pad that quite sticky for a small heatsink.
Well it already has thermal paste on it and the heatsink that came with the board (MSI 970 GAMING)
Breaking things 1 day at a time
https://linustechtips.com/topic/628243-northbridge-cooling/#findComment-8102493
3 minutes ago, TubsAlwaysWins said:
Liquid and what is hsf
hsf = heat sink and fan. As long as you have decent case airflow so the heat sink on it gets some air flow over it, you're fine.
CPU: Intel i7 4770k w/Noctua NH-D15, Motherboard: Gigabyte Z97 Ultra Durable, RAM: Patriot 8Gb 1600Mhz (2x4Gb), GPU: MSI R9 390x Gaming,
SSD: Samsung 840 EVO 1Tb, HDD: Caviar Black 1Tb, Seagate 4Tb Hybrid, Case: Fractal Design Define R4, PSU: Antec Earthwatts 750w
Phone: LG G2 32Gb Black (Verizon) Laptop: Fujitsu Lifebook E754 w/ 1TB Samsung 840 Evo SSD Vehicle: 2012 Nissan Xterra named Rocky
https://linustechtips.com/topic/628243-northbridge-cooling/#findComment-8102545
