hi
i am new to online gaming and bought sennheiser game one's and i have only used them on ps4 so far ,but the volume is to low.
i will mainly be using these on the PS4 but i f might also use them on the pc soon.
my question is :
do i need an amp with a dac ?
. i found one with a dac but it isnt as loud as the one without and i have no idea how much loudness is gained by either or the quality sound of either.
which one should i get out of these ? (or any suggestions)
Fiio E17 Alpen 2 (dac)
Bravo Ocean (no dac) but i heard its more powerful ,but to what degree and is the extra power needed for sennheiser game ones...?
Thanks
core ultra 7 series 2 , 48gb ram , zotac 4090 trinity oc ,z890 strix-e gaming , 7.1 kilpsch rp series , denon srh750 ,lg c3 77 inch , antec c8 curved wood case
https://linustechtips.com/topic/628172-help-on-amp-vs-ampdac/
5 minutes ago, noobbuilder said:
hi
my question is :
Thanks
You need an amp if your PC cannot power them properly. You probably have a good enough DAC but if you can splurge then the DAC+Amp combo unit, the Micca Origen, is good and should work fine.
https://linustechtips.com/topic/628172-help-on-amp-vs-ampdac/#findComment-8101836
thanks for your response . the Micca Origen from what i can tell only has usb input . i need one with 3.5mm input and output to be compatible with the ps4. i not positive though thats just what i heard it has something to do with how the mic and headphone jack being a single 3.5mm ouput the ps4 controller.
https://linustechtips.com/topic/628172-help-on-amp-vs-ampdac/#findComment-8102000
