5 minutes ago, loljaska said:
ok so here is a plan what i could be doing next spring, http://pcpartpicker.com/list/cwMHhq
i already have the 1070 and an 1TB HDD im planning on using, also the motherboard ive been looking is the DDR4 version (http://www.gigabyte.com.au/products/product-page.aspx?pid=5590#ov) and also the memory will be DDR4 ofcourse. so, what do yall think, any bottlenecks? overkills? compatability issues?
WHy get a 6600k with a 150 chiupset mobo?
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/628109-pc-build-plan/#findComment-8101145
I'd get an i7/xeon instead, an i5 will bottleneck the gtx 1070.
https://linustechtips.com/topic/628109-pc-build-plan/#findComment-8101365
