Hello!
I have 2 systems: PC and MAC... and one sound system that I can use P2 (aux cable) to select the audio between PC or MAC. If I want use the PC, I need to plug the P2 in my PC, and if I want change to MAC, I need to unplug from PC and plug in my mac...
Is there some way to connect both together and I select from one of the systems ? Thanks
https://linustechtips.com/topic/627812-multiple-audio-devices/
20 hours ago, vitarely said:
Thanks megaant4 ! Do you know some model to recommend for me ?
No problem. This is the cheapest one I have found..
https://www.amazon.com/Nady-MM-242-Stereo-Channel-outputs/dp/B0009XH4HU/ref=sr_1_fkmr0_1?ie=UTF8&qid=1468814798&sr=8-1-fkmr0&keywords=Nady+MM-242+4%2F8+Channel+Mini+Mixer
Should do the trick. Depends on how much you want to spend.
https://linustechtips.com/topic/627812-multiple-audio-devices/#findComment-8102604
