So i've been recently trying to overclock my 8350 but i've been having this strange issue when the CPU (according to openhardwaremonitor) Reaches around 60 celsius usually around 55 to 56 the clock speed changes from something like 4.7 GHz to 2.8 And I don't know why its doing it if anyone can help it would be greatly appreciated.
Thank you in advance, LazyChaz
PC:
CPU: Ryzen 9 3900X @ 4.25GHz
RAM: 32GB Patriot Viper Steel 15-15-15-36 @ 3600MHz
Motherboard: Gigabyte Aorus Master X570
GPU: Powercolor RX 6800XT Liquid Devil
SSD: 500GB 970 Evo Plus, 500GB Pioneer NVMe, 480GB BX500 SATA.
PSU: Corsair AX1600i
Cooling: EKWB Watercooling
Case: O11 Dynamic XL + EKWB Reflection distro plate
Laptop: Framework Batch 10
I5-1135G7
24GB 2400MHz
500GB PM951
https://linustechtips.com/topic/627809-fx-8350-overclocking-issues/
Sounds like you have turbo enabled in the BIOS (allows the CPU to adjust it's frequency). I would turn it off, but I could also be wrong
Also what are your voltages?
Breaking things 1 day at a time
are you reffering to the the core performance boost because that is what i see as a "turbo" feature
PC:
I5-1135G7
24GB 2400MHz
500GB PM951
2 minutes ago, TubsAlwaysWins said:
I don't know. Sounds about right
yeah thats been turned off but I now have a new problem in which openhardwaremonitor isnt even giving me temperatures
PC:
I5-1135G7
24GB 2400MHz
500GB PM951
as a quick update I managed to fix the temperature not displaying but the CPU is still underclocking when the temperature gets near 60 C and I still dont know why if anyone can offer some insight as to why it would be greatly appreciated
Thanks in advance, LazyChaz
PC:
I5-1135G7
24GB 2400MHz
500GB PM951
The AMD chips thermal throttle at 62C (package temp) AFAIK
What are the individual core temperatures?
CPU - i7 6800k @ 4.2Ghz
Mobo - Asus X99-A-II
Ram - Corsair Vengeance LPX White 32GB @ 3200Mhz
GPU - MSI GTX 1080ti Lightning X @ 2063/12528
Storage - Samsung SM961 256GB, Samsung 840 Pro 250GB & Sandisk Ultra II 256GB
Cooling - Corsair H110i (2x ML140 White LED)
PSU - RM850x
Case - Anidees Ai Crystal
Monitor - Acer XB270HU bprz @ 1440p / 144hz IPS
Sound - FiiO E10K & AKG K712 PROs
Peripherals - Razer Blackwidow TE & Corsiar Scimitar
Lol I don't allow mine to throttle. If he could disable throttling it should fix it
  • 3 weeks later...
sorry for the really late reply I've been very busy anyway do either of you know what to disable in my BIOS to disable this feature?
PC:
I5-1135G7
24GB 2400MHz
500GB PM951
Make sure you have both TurboCore and APM disabled in the bios.
right ok ill go do that now
PC:
I5-1135G7
24GB 2400MHz
500GB PM951
I am in the process of moving right now so I din't quite remember, but I think it was turning off Turbo or something close to that. I know it was under the OC tab of my board (MSI board). Who makes your Motherboard?
mine is gigabyte although its not using a UEFI its a legacy BIOS based motherboard its also not exactly high end considering its only a SATA2 and Pcie generation 2
PC:
I5-1135G7
24GB 2400MHz
500GB PM951
sounds like the VRMs on the mobo has given way.
it not sustaining enough juice for the FX8350
you prob need to change the mobo to at least the AMD 970 chipset like the MSI 970 Gaming or the MSI 990FX
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
