Hi,
I'm looking to build or purchase my first gaming rig and I'm not sure where to start. Please could someone recommend me a supplier or if I was to build my own point me in the right direction?
I live in the UK and I dont want to spend any more than £2000 GBP / 2640 USD / 2390 EUR
For that sort of budget I would like something pretty future proof, I'm not strapped for cash and have saved hard so I want to make sure I'm definately getting the best bang for my buck!
As I have no experience, if I was to build my own I would prefer to avoid water cooling as it seems way too advanced for me.  Im thinking of copying this build exactly, as there is a video etc..
https://linustechtips.com/topic/627421-first-build-or-purchase/
3 minutes ago, Alexford said:
What would you recommend? My biggest fear is compatibility. If I was to build I'd like it to be as stress free as possible.
See that's the thing, AIO coolers have multiple possible fail points which could cause your computer to be drenched in water. I too have an AIO only for the reason that I don't like having a big heatsink blocking half of my motherboard for show.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/627421-first-build-or-purchase/#findComment-8093896
37 minutes ago, Alexford said:
Hi,
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  (£298.73 @ Aria PC)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  (£107.99 @ Amazon UK)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  (£127.43 @ Amazon UK)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  (£54.99 @ Ebuyer)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£72.99 @ Amazon UK)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  (£99.99 @ Amazon UK)
Video Card: Zotac GeForce GTX 1080 8GB AMP! Extreme Video Card  (£670.33 @ Aria PC)
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case  (£90.99 @ Ebuyer)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£99.98 @ Novatech)
Total: £1623.42
Generated by PCPartPicker 2016-07-16 15:37 BST+0100
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/627421-first-build-or-purchase/#findComment-8093998
