searching for good rgb ligts to put in my case
Alexzz_
I am searching for good RGB lights to pimp my case. Im willing to pay up to $35. What are your suggestions?
Quite good. Some flaws:
-Did not include 3xAAA batteries for remote
- (small) control box that needs to be placed somewhere. I tried placing it in the PSU shroud of my case, was perfect!
-The tacky sticker part on the back on the LED strips that you peel off loses its stickyness quickly, however that was an easy fix with super glue!
-remote is ... touchy.
-The brightness only works with static colors.
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
If you're good at something, never do it free.
Most of them are easy to fix but thanks for mentioning them
Maybe something like this
http://www.banggood.com/44-Key-Mini-IR-Remote-Controller-Control-For-3528-5050-RGB-LED-Strip-Light-p-972358.html
http://www.banggood.com/1-To-3-Female-4-Pin-LED-Connector-Cable-Splitter-For-RGB-3528-5050-p-957033.html
http://www.banggood.com/1M-3528-SMD-60LED-Flexible-LED-Strip-Light-RGBRedBlue-Non-Waterproof-12V-p-974792.html
cost you about 5 bucks for one rgb strip, 7 bucks if you want two etc, you can take more. and you need a power supply
but you wont be able to control it through computer just with a remote
im thinking about ordering myself
