Game problem
Solved by itsMilan,
1 minute ago, Kurt101 said:i own a really cheap phone (like $20) i could not care for iphones, so im sorry but that is unavailable as the camera is welll. you get the idea. but i can tell you i have tried V sync, but nope, it does not work
Hmm, it's really hard without some footage but let's run down your options:
- Try to use GeForce Experience. (Or the AMD one, can't remember the name.)
- Update Windows
- Update Windows Drivers (DirectX, Vistula Studio)
- Verify game flies if you're using steam/origin
- Reinstall game, with backing up your safe file ofcours.
And if nothing works said by me or someone else, then your last option is:
- Reinstalling Windows
