So I have a broken 2009 iMac, and since it's not really worth a whole lot, I figured I may as well have fun with it. My plan was to hack it into a monitor and do a bunch of cool mods to the case, and at a later date when I have some more money (I'm only 16btw) I want to try to build a small itx computer inside of it. One of the first mods I wanted to do was to add rgb LED's to the two black Mac logos that are on the bottom and back of the machine. After tearing down the entire machine, I was able to pry out the Mac logo from the back using a screwdriver.image.jpg
what would be the easiest way to reproduce this part using clear acrylic? The Apple part is cnced, but I do not have access to a CNC so is there another way I can easily do this? The logo on the bottom was much easier to deal with, as the plastic is already clear with black layer painted/ attached into it. I was able to sand it off with 150 grit sandpaper, and after I sand it with some higher grit sandpaper and buff it should look good.  image.jpg
What would be the best type of LED's to use? Also, how would I power these LEDs? I have 120v going into the iMac through this partimage.jpg
, so what would be the easiest way to get that 120v to correct voltage needed for the LEDs?
thanks in advance,
bgibbz
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/626086-help-with-a-mac-mod/
upgardeing a mac is HARD....
very few things can be upgraded,
i do have a imac but it's to 20 inch and made in 2008, the only things i could upgrade and this the same for most macs is the hard drive and RAM
and for modding it to be a new monitor, you are out of luck the pin-out is different than a normal monitor and i think they use a different encryption method
****SORRY FOR MY ENGLISH IT'S REALLY TERRIBLE*****
Been married to my wife for 3 years now! Yay!
https://linustechtips.com/topic/626086-help-with-a-mac-mod/#findComment-8079547
I read a couple of online guides that recommended using something called a vga control board. https://www.ifixit.com/Answers/View/117066/Can+I+Mod+an+early+2009+24"+iMac+to+external+monitor
that was my primary source if information. I found a vga control board matching the model # of my display and I ordered on eBay for 25$. Should get here within a week or two. Il test it out then.
https://linustechtips.com/topic/626086-help-with-a-mac-mod/#findComment-8079560
2 minutes ago, samiscool51 said:
ok, but don't be surprised if it does not work, apple components are VERY picky
Yep. That is precisely why I hate working with macs, but the display is an lg display used in a variety of systems, not just macs. My plan is to gut everything that's Apple from the computer (which I have already done) and only use the lg display and the 3rd party controller in order to make the device function as a monitor.
https://linustechtips.com/topic/626086-help-with-a-mac-mod/#findComment-8079585
