Ok, I am having a weird problem. My primary computer is used mostly for gaming/video editing/VR with my HTC Vive specs are:
  • CPU - Intel i7-3770K with the stock cooler
  • Motherboard - ASUS P8Z68-V Pro Gen3
  • 16GB Ram
  • Nvidia GTX Titan 6GB referance card
  • Rosewill RBR1000-M 1000W Power Supply
  • a SanDisk 256GB SSD and 2x 2TB HDDs
  • Windows 10 64bit
My problems started a while after I switched out my old GTX 660Ti to the GTX Titan. I did this so that I could get better performance in Premier and to support the VR headset I bought shortly afterward(I now wish I had waited for the 1080). The install went perfectly, with the only hitch being I had to rearrange all the hard drives so that my power supply cables would reach. But after a couple of weeks I was playing Battlefield Hardline when all of my screens went black and all of the Fans went to full on. I have never heard the computer be so loud. Figuring that it had overheated and shut itself off, I took the side panel off and left it running while I went to lunch. When I got back almost 45min later it was in the same state. Powering it off and back on it came back up and started working normally like nothing had happened and I proceed to play battlefield for several more hours with no issues. It has happened 2 more times now, it only happens when I play Battlefield 4 or Hardline. What I don't understand is why those games trigger it when I have have had zero issues using the exact same rig for VR. Is Battlefield more power consuming than VR?
I'm not sure how to proceed, should I look into better cooling? I don't have room or the desire to water cool, but I am only using stock fans. I have 2 in the case, one intake at the back and one on the top blowing out. The CPU and GPU both have the stock coolers on them and the power supply has a couple fans in it as well. This has been enough for me in the past, but I also had a smaller graphics card before this started happening.
https://linustechtips.com/topic/626070-possibly-overheating/
definitely seems to be over heating...
is it OC? if yes deactivate it and try playing battle feild again to see if it happens again
****SORRY FOR MY ENGLISH IT'S REALLY TERRIBLE*****
Been married to my wife for 3 years now! Yay!
https://linustechtips.com/topic/626070-possibly-overheating/#findComment-8079284
I don't believe it is. I don't know much about how overclocking works so I haven't tried, but I did buy the card used so if they overclocked it could it still be?(again I don't really know how OC works)
https://linustechtips.com/topic/626070-possibly-overheating/#findComment-8079297
Go into the GPU drivers. If it's OC'd, "reset to default". Run both gpu and cpu benchmarks and tell us the temps.
https://linustechtips.com/topic/626070-possibly-overheating/#findComment-8079306
2 minutes ago, samiscool51 said:
i would recmend cinebench and chouse the OpenGL in advanced options
Cinebench not bad either but that renders a scene in openGL and that's not really heavy. Furmark simulates a REALLY GPU heavy game, kinda. Furmark is a stress test.
https://linustechtips.com/topic/626070-possibly-overheating/#findComment-8079336
Cinebench is a great software to bench CPU's
CPU-Z is also a option and alows for indefinite stress tests, great is you want to test your OC
i fact i use both of the programs for testing old hardware to see if it can handle a modern task maost tasks today would be like playing a high end game back when the CPU was new
https://linustechtips.com/topic/626070-possibly-overheating/#findComment-8079350
23 minutes ago, zdog16 said:
Ok, here is the preliminary results from Cinebench with the specs from CPU-Z on the CPU and GPU I am running benchmarks in CPU-Z now
Please do a furmark test on max settings. If temp goes over 90-100C then your gpu might be overheating. I highly doubt that BF4 is that heavy though.
https://linustechtips.com/topic/626070-possibly-overheating/#findComment-8079505
6 hours ago, zdog16 said:
Ok, I think I found something, I downloaded CPUID HWMonitor and the core temps on the CPU are high.
So I guess I need a better cooling solution...
I suggest a corsair h55. It's £50, easy to install and keeps my temps around room temp. It's a liquid cooler so no water refilling necessary. I highly recommend it for cpu cooling.
https://linustechtips.com/topic/626070-possibly-overheating/#findComment-8080951
