7 minutes ago, darkninja8888 said:
Hi i'm trying to figure what to clock my CPU to. I want to keep a cool temperature. My PSU is 650W so I think I should be okay but correct me if I'm wrong. Here is the build http://pcpartpicker.com/list/7F7MZ8
every chip overclocks different so you just need to try.  and keep the temperatures under 80c
https://linustechtips.com/topic/625851-oc-clock-speed/#findComment-8076759
should be able to achieve 4.4 ghz easily.  If you are new to overclocking, Asus auto tune in your BIOS can probably do that for you with one click.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
https://linustechtips.com/topic/625851-oc-clock-speed/#findComment-8076765
10 minutes ago, Skittels said:
I think 4.00 Ghz is enough everything above that will probably not work without increasing the voltage.
Not really, it depends on the chip, if he has a good one he could even OC it to 4.2-4.4 without changing the voltage. And even if he has to, it's worth it!
https://linustechtips.com/topic/625851-oc-clock-speed/#findComment-8076821
