Borderlands 2 problem
Go to solution Solved by WhitePandah,
try disabling vsync, it might be causing the problem
Im playing borderlands 2 and im getting random drops to 30fps exactly on my gtx 770. When i fast travel it will limit its self toi 30 for awhile then go to full 60. In some fights it randomly goes and stays at 30. I have it set to unlimited in the settings though any ideas?
My rig  case- Graphite 600t white CPU-i5 3570k OC 4.0Ghz RAM- 8gb Vengeance memory HDD-WD Black 1tb PSU-tx650 GPU- MSI 770 gameing edition 2gb , gtx 650 1gb Motherboard- asrock extreme 3 z77 Fan controller- NZXT sentry lx CPU cooler- H60 Peripherals- g300 mouse G630 headset k70 silver cherry mx red switches  my free nas nas Case- Dell something.. Ram- 8 gb ecc ddr 2 CPU - Pentium D 3.0ghz HDD currently 160 gb adding 3tb wd red “Sucking at something is the first step to being sorta good at something” –Jake the Dog
https://linustechtips.com/topic/62559-borderlands-2-problem/
Do you have Dynamic Vsync on in nvidia control panel?
I am not using dynamic vsync . I am going to turn it off and try it now.
https://linustechtips.com/topic/62559-borderlands-2-problem/#findComment-854718
ok with v-sync of it stopped. Just thought it was weird that i was getting random 30 fps caps in places. Thanks for the help :)
https://linustechtips.com/topic/62559-borderlands-2-problem/#findComment-854741
