I just upgraded from an unactivated version of windows 10 to windows 10 pro.
When upgrading, I made it so that I would remove all files. It appears that I did lose all files, but on my HDD and SSD it still shows that my files are in there.
Is there a way to wipe my HDD's without losing my OS? Thanks
maybe theres a way to wipe everything but the OS in BIOS?
https://linustechtips.com/topic/625257-hard-drive-question/
On the windows 10 search, search for refresh. Follow the instructions and you will get an option to keep or remove your files.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/625257-hard-drive-question/#findComment-8070033
That brought me to "reset this pc". i proceeded to remove all files but it said no changes were made.
https://linustechtips.com/topic/625257-hard-drive-question/#findComment-8070071
Hm, I'm not sure then. That is what I have always used to wipe my hard drive. Try booting into a windows 10 boot cd or USB, the. Clicking repair when that loads. That should reinstall the OS from the ISO and not form the win10 files that are saved on your computer.
https://linustechtips.com/topic/625257-hard-drive-question/#findComment-8070087
