Currently looking for a case, most likely a small case while leaving enough room for airflow and easy to upgrade (space to move my hands about in). I was hoping for one below £50 (preferably off of Amazon.co.uk) Thanks!  My components are: R7 370 GPU, FX 6350 CPU, any atx/ micro atx motherboard, 1tb HDD and ram.
https://linustechtips.com/topic/625120-need-help-picking-a-case/
if you want you can go for an atx mobo and go for a simple case like corsair carbide 200r
CPU:Intel Core i5 6600K 3,5GHz  Motherboard: Z170 PRO GAMING  RAM: HyperX X Fury black DDR4 2x4GB
GPU: AMD Radeon HD 7800 series Case: some random shit tho it is gonna be upgraded Storage: SanDisk SSD Plus 240GB Cooling: Cooler Master Hyper 212 Evo Display: Asus VS278Q Keyboard: Roccat Arvo Mouse:Razer Naga 2015 Edition OS:Windows 10
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068391
200r_hero_up.png iwould go for corsair carbide 200r easy for a new builder and a really clean look you could go with stealth if the sound is an issue but less air cooling
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068414
Now if you are for some lan parties you could go for an micro atx and have an  bitfenix prodigiy m or go with haf xb evo if you want a full blown atx lan box (im gonna buy it soon) <3 but those are a bit more expensive atleast in sweden
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068420
looking for a micro atx one on the cheap , less that £50 and if it is bigger it should have support for both atx and micro atx
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068436
why not just go for atx board ? full fledged board with all the features
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068450
1 minute ago, Nahidul said:
a recommendation under £50? thanks
a atx board under 50 euro ?
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068460
4 minutes ago, Nahidul said:
case and board (am3+) total price around £80-£90 should be good
i guess micro atx it is cuz with that tight budget you will just end up with an low end mobo that can be outpreformade but an micro atx i belive
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068474
2 minutes ago, Nahidul said:
What does an atx board have that a micro atx does not?
sli and crossfire and better air flow so the board does not sit so tight aka if you have 2 gpus so they dont sit tight togheter and sometimes sli and crossifre is good for budget people and and atx has more ports and more pci lanes and somtimes more ram lanes which is always good for expansions and more. idk it feels like micro atx is a wierd form factor so if your going micro might aswell go for atx and get the *full package*but if your going mini and want sometime portable sure
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068492
Yeh micro atx it is not going to do crossfire or sli and can find one with 4 ram slots easily im sure
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068503
yes i guess idk id rather wait in your position if your not in a rush or but a decent mobo and go for an used case on ebay or something
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068516
thanks for the help, actually planning on getting everything new actually and ASUS, Asrock and Gigabyte seem to make good M-ATX mobo
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068528
sure may i ask what gpu if anny gpu ?
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068536
R7 370, left the specs at the top of the post
fuck i derped sorry ok good choice was just wondering
https://linustechtips.com/topic/625120-need-help-picking-a-case/#findComment-8068549
