I am using a copy of Windows 10 Home 64-bit on my Asus laptop, I also have a copy of Windows 10 Pro 64-bit on my Thinkpad x61. I was wondering, is it possible to use the thinkpads product key on the asus, and if so can I activate it as a windows 10 pro os as oppose to a home os. If I activate it will it have any negative effects such as broken files? If It worked would it restore my system to factory new?
IM BACK BABY
https://linustechtips.com/topic/624889-changing-product-key/
unless you bought a retail windows key (for $120), the keys are tied to the motherboard and cant be transfered
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/624889-changing-product-key/#findComment-8065723
