custom cable extensions worth it?
Go to solution Solved by CableMod,
6 minutes ago, ryan_BO2 said:
hey
are custom cable extensions worth it? i am looking to buy these ones: http://www.informatique.nl/563893/gelid-solutions-24-pin-extension-cable.html http://www.informatique.nl/563898/gelid-solutions-6-2-pin-pci-e-extension.html
thanks in advance
greetings Ryan
they certainly are if you care about the look of your system - we have wide range of extensions available in many colors and they are available in NL as well: http://www.highflow.nl/?subcats=Y&pcode_from_q=Y&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&search_performed=Y&q=cablemod+extension+kit&dispatch=products.search
(FYI - also cheaper than the GELID ones ;))
hey
thanks in advance
greetings Ryan
https://linustechtips.com/topic/624504-custom-cable-extensions-worth-it/
hey
thanks in advance
greetings Ryan
