After build
Go to solution Solved by saladcrack,
Yes HDMI into the graphics card. And Newegg has a great video on installing Windows and final touches.  The process might differ a little because the video is 5 years old but it should be fine.
I have a question about after building the pc. To install operating system which is windows 10, do i connect my hdmi cable to the motherboard or my graphics card? There are lota of great videos about how to build a pc but there aren't much about instaliing os and setting the computer to get it ready for gaming.
https://linustechtips.com/topic/624278-after-build/
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/624278-after-build/#findComment-8057067
If you have a dedicated GPU, plug your display cable into that.
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
https://linustechtips.com/topic/624278-after-build/#findComment-8057159
