 So are you looking for just a decent lga 1150 motherboard?
Any other requirements such as expansion/io ports, price, or sata ports?
Most motherboard will have a few years warranty on them.
Here is a few under $100, as this seems like a more budget orientated build.
http://pcpartpicker.com/product/YDrG3C/asrock-motherboard-h97manniversary
http://pcpartpicker.com/product/3mPzK8/asrock-motherboard-h97anniversary
http://pcpartpicker.com/product/MPtCmG/gigabyte-motherboard-gah97mhd3
http://pcpartpicker.com/product/FkCwrH/gigabyte-motherboard-gah97md3h
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/624274-need-help-with-mobo/#findComment-8057285
Yes, thank you. I appreciate it. I forgot to put a price limit, under $100 was exactly what I was going for.
https://linustechtips.com/topic/624274-need-help-with-mobo/#findComment-8057290
1 hour ago, Goot said:
First build with an i3 4160, and GTX 960. 2 x 4GB memory. NZXT s340. Can not stick to a motherboard to buy. It's not going to be a complete, final build motherboard, but will need to last for a decent period of time
Here. Same build, but better. Browse the 970 on the used market, you should be able to find some sweet deals.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($110.99 @ SuperBiiz)
Motherboard: Asus H110M-A Micro ATX LGA1151 Motherboard  ($51.98 @ Newegg)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($30.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($0.00)
Total: $193.86
Generated by PCPartPicker 2016-07-10 23:59 EDT-0400
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/624274-need-help-with-mobo/#findComment-8057569
